for help
sminage
cable operator
india
My reciver is sr-x3200cu . I cant upgrade this
receiver to get scrambled channels .which software is
suitable for this and how to use it. I have rs232
cable with me.
when I select for private message the aneswer is `you have no right` .
how can activate my account fully .
I activate my account as seen in my confirmation mail.
plese help me as soon as earlier
thangs for your help.
sminage
You have activated your account correctly but you won't be able to send any private messages until you have made a few more posts here. This is a safety precaution, make a few posts and you'll soon be able to send messages.
However, it is not considered good etiqette to send PMs if it is a question that could be answered in the forum. If you send a PM to a Mod or Admin which should be on the forum they will ignore it.
Finally, this is a satellite forum and if your box is for cable then we aren't able to help. Sorry.
Thats probably a Starsat model. If so, theres shedloads of info about them on the forum using the search feature. And I think we will move this into the receiver software section as its really in the wrong part of the forum.
