Fortec Diamond help with keys
S
simmy
Likes
1mtr Triax dish gold lnb
fortec diamond ci reciever
derbys/s.yorks
#1
Hi all
could somebody point me in the right direction for updating keys on the above system it is patched but need to get some keys in so i can watch the pron when wife goes out ;) i have the codes menu there but aint got a clue on how to do it total n00b i also have a program called key enchanter found some keys but the keys are .cod format and the keyenchanter needs .ke i believe
any help would be gratefull
regards si
Likes
3,436
In the code menu, input 1668 to get to the encryption systems.
Rename .cod file to .ke2
S
simmy
Likes
derbys/s.yorks
#3
thanks for that info
if i press 1010 that shows me the encryption stuff is that the same thing also can i upload the .cod file after renaming to .ke2 using key enchanter?
regards
Si
Likes
3,436
Yes, that's the other code entry combination.
And yes, .cod files renamed .ke2 are used by Keyenchanter.
D
danda
Likes
USING A LIFETIME DECODER
PENTIUM 4 ON WIN XP
Harare Zimbabwe
#5
someone tell me what a key enchanter is? I am using a fortec lifetime decoder
Likes
3,436
A program that allows you to upload satellite transponder settings to your Fortec.
Find it here -
_www.zackyfiles.com/secciones/dekos/fortec.htm
