freecam seca problem
  • Thread starter Thread starter watdav
  • Start date Start date
W
watdav
i have recently patched my irdeto se4.7 cam to freecam 2.017 and have been experimenting with DS9 5in1 files (silver card) on a nokia 9600 running dvb2000. They work fine with irdeto and viaccess channels, but not with seca/nagra/crypto channels. On these the receiver comes up with 'sys' - (ie cam not recognized) rather than 'crd'(cam recognized but wrong key). This happens even when goodies menu item2 is switched to seca. Anyone got any tips?
[updated:LAST EDITED ON 08-Dec-01 AT 04:12 PM (GMT)]You can get your set up to work with the latest DVB versions, but it's not worth the bother (too unstable) and you won't get every channel.
The answer for anyone with a 9600 (not 9200/9500) is to load DVB NoOneManIt and you can get everything (I+Ib+V+S+N but no C). Some channels may need to be manually activated but it does work and you learn a lot more about what's going on.
Also, there was no need to change your cam from 4.7se to freecam, but don't bother to change back now you have flashed it once (NB this info is for 9600 users only).
Thanks for the advice! I have not come across DVB NoOneManIt. Is it a specific version of DVB 98/2000? Where can i download it?
Thanks Burnham Beech. But sadly that link no longer allows access.
However, for others who are interested, I have found the NoMan firmware here:
http://www.mantraandy.com/Utility/Nokia/DvbNOM2001-11-02.zip
It works great with the 9600 - my congratulations to the NoMan team!
