thanks rolf i get bbc on analogue from brougher mountain at the moment its a bit snowy picture is it worth trying digital or would it be poor picture ^-Jrolfw said:If you can receive from one of the transmitters mentioned on This page you may be in with a fighting chance.
big foot said:thanks rolf i get bbc on analogue from brougher mountain at the moment its a bit snowy picture is it worth trying digital or would it be poor picture ^-J
hi rolf im about 100-120 miles from transmitter i can also get divis transmitter but very poor good in good weather but in bad weather it keeps going i need two go up a lot higher i dont want two do that divis is aprox 150 -170 miles :-bandrolfw said:Digital signals can sometimes be surprisingly good compared to their analogue counterparts, but as a general rule, if you get a bad analogue signal, you will get a substandard digital signal. The digital signal from this transmitter is only 0.5KW, so not very strong, you may find though, that putting up a higher gain antenna on a taller mast may produce dividends.
As a matter of interest, how far are you from the transmitter?
