Fresh One !! need help
albalaji
Hi experts...
I have old Irdeto CAM ... When i check it on my recivers i found old SW for it then When i search intrenet i found NEW SW >>>
- How i can uppdate (upgrade) my irdeto cam? Is it nessasery To do it?
- I have laptop Toshiba A100. Windows xp proffesional >>
- What i need to do that ?
Plz Help >>>>>
i'm sorry for late ...
Now i don't have scanner to do What you asked.... But i have those informations from my recivers :
"Irdeto Common Interface Ver:01.06SoftCell :ver 2.09 CIS-Demux(SWCA)"
Thanks for help >>>
According to this site, the CAM cannot be programmed with a Laptop. Why do you want to change the software?
albalaji said:
Because i lose my signal sometimes I have Humax icord Receiver ...
Assuming that you have an official smart card, is it possible that the problem is due to the provider ?
Also, maybe the receiver is faulty.
Can you try the CAM in another different receiver with CI slot and see what happens ?
I fried my CAM once when I tried to update the software and I don't want you to lose it also.
I will explain to you >>>
I have Two subscribtion ONe is SHOWTIME and other is ART SPORTS...
Befor i use Star sat recivers When i watch some channels on SHOWTIME for one hour .. then i change to any ART chanels it gives message like " Scrambled etc..." then i must turn of Receiver and ON then it's apper for ART ... For that reason i bought HUMAX recivers With new SW and it's fine BUT still problem presents !!!!!
I talk to HUMAX support the are said mybe from your CI module ...
thanks
I also switch off my receiver for different cards and it doesn't bother me.
The main thing is that you can still watch your favourite channels by switching on and off.
It is up to you if you want to risk it, but as rolf mentioned, don't use laptop.
Maybe you can update it by leaving the receiver on a certain channel. Check the internet.
I updated my red Viaccess CAM by leaving it on a certain channel.
Update:
I read that to upgrade your CAM to version 1.10, you need to use Nokia 9600S receiver and a PC with either Windows 95 or Windows 98 and use a SCSI card and a SCSI cable to connect between the PC and Nokia Receiver and the software.
The problem is that the Nokia 9600S SCSI connector is subminiature and you need a suitable cable to connect to it.
Unless you can prove to yourself that upgrading to 1.10 would solve the problem, there is no point to waste your time to do all the upgrading process.
Can you find such a CAM and borrow it just for few hours ?
If you have a second receiver with CI slot and another IRDETO CAM, you can leave the two cards in all the time. You may need to add a DISEQ, but that is a very cheap part.
Another possibility is to send the CAM to a specialist who will upgrade it for you for a fee. Few years ago, there was such a shop in the UK.
Dear HB13DISH and albalaji,
I read your thread. I also have an icord irci-pvr and it hang. Can you guide me to the sw and loader program?
_http://www.humaxdigital.com
Go to Support and choose iCord HD
Found this. Make sure it is suitable for your own receiver.
DL from website
SW version GXLSCI 1.00.07
Datum 31.03.2008
Update at your own risk
