Frozen and locked!! Help
scottgough
Fortec Star Passion
United Kingdom
I've managed to get my receiver locked, was just channel surfing, went onto ch 6494 I think, now it wont move or respond, tried turning it off and on and just goes back to this channel, is there a way of hard resetting? baring in mind i cant use the software menus? Thanks
scottgough
Fortec Star Passion
United Kingdom
sorted thanks, removed the sat lead so it couldnt get a signal, which stopped it locking on! phew
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
I hope you powered it down first, or at least before you re-inserted the cable from the lnb
tricky1
fortec star passion
uk north london
Hi there i had the same problem and done exactly the same thing is unpluging the cable a stupid thing to do can it cause some damage while the thing is still switced on.
scottgough
Fortec Star Passion
United Kingdom
yes, powered it off first, disconnected, then fired back up! ;-)
tricky1
fortec star passion
uk north london
Well looks like i was lucky this time will make sure its switched off next time. cured the problem though.
That is a fault that used to occur on some of the early Samsung receivers.
The channel that you are watching is transmitting outside the DVB minimum requirements, and will cause the receivers firmware to 'cycle' whilst trying to process logic from the data stream.
Which channel caused the loss ? and have you deleted it from the channel list ?
tricky1
fortec star passion
uk north london
Well the channel it got locked on was BBC HD
This latest (beta) firmware cures the BBC HD locking problem -
Download Link
http://rapidshare.com/files/118233628/p_av113_20080525.zip.html
tricky1
fortec star passion
uk north london
Thanks LIew its been ok for a few days now will try the new beta if it happens again that version is not on the fortec website are you one step ahead of them?
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
That'll be firmware from laurals on the sataid forum.:)
clobryn
fortecstar Dreambox 7020si
Sky+
Wales
Download Link
can confirm this patch Llew posted works A1 thanks
