Frozen Diseqc motor
gandalfthegrey
Specialised Contributor
Dreambox 800HD (clone)
Gibertini 85cm dish
4 way Diseqc switch........
linksys access point connected to Dreambox..
dublin,ireland
Hi guys...
Hope this is the right forum for this post..I bought a Superjack DG120 diseqc motor late last year, I hadn't used until this week when I went to do a test connected to the reciever before I installed it..the motor moved a few degrees and froze and now I cant move it back it looks like no power is getting to the motor..any ideas...please
Does that model have controls on the motor as well? If it has, have you tried using them?
Hi rolfw..
Yes the motor has a left and right manual switch but I'v tried these as well and no joy..any ideas..anybody
Cheers
Well if there is power going to it and the manual switches won't work, it will be a case of return to supplier.
Thanks rolfw for the reply..
I sent off a mail to the supplier in Germany but got no reply so out of frustration I brought the motor into an electronics expert in work who is looking at it as I type..so I'm sure this nulls my waranty....hard lesson learned if it does!!
Cheers anyway
