FTP Connection Problems
beatphreak
dreambox 7000s - Flubber
40gb Hard Drive
80cm Clear Dish + V-Box 2
Linksys Wireless Bridge
DCC on Laptop
Lancaster UK
Can someone advise me on a connection problem plz?
When trying to connect to my db7000-s via dreambox keyfile updater on a laptop i'm getting 'are you sure the db ip is correct!'
My settings are
IP: 192.168.0.24
netmask: 255.255.255.0
Type: Lan
Nameserver: 192.168.0.1
Gateway:192.168.0.1
Enabled network and saved it
port 21 (tried 80)
anbody any thoughts
RedDevil_UK
Retired Mod
Dreambox 7000S, VU+ Solo2, 1.1m Dish, Moteck SG-2100A DISEQC Motor
Rochdale
that looks ok to me??? is the cables OK
i set my PC to 192.168.0.1
and my DB to 192.168.0.2
255.255.255.0
crossover cable from PC to DB direct
i enabled internet sharing on PC too
it all worked first time
check its not the program first.... goto your web browser and put the address in as
ftp://root:dreambox*192.168.0.24/
change the * to AT sign... this forum wont except AT signs??
see if you log in....
beatphreak
40gb Hard Drive
DCC on Laptop
Lancaster UK
The cable is ok and the browser ip didn't work..
where did you enable internet on your pc
I have a wireless card in at the same time and if i try to enable it say that the is an ip clash, but if diasble it it won't let me enable anywhere...
Do you have a firewall enabled by any chance? If so you may need to change the settings to allow access to the db.
beatphreak
40gb Hard Drive
DCC on Laptop
Lancaster UK
only the one on XP, but when i disable i still can get in.
RedDevil_UK
Retired Mod
Rochdale
you first need to make a good network connection then...
to enable internet sharing click..
start > connect to > show all connections
this opens a window showing network connections and your internet modem/connection
Right mouse click your internet connection and choose PROPERTIES
click onto the ADVANCED tab...
now click the second tick box down under the heading INTERNET CONNECTION SHARING
the tick box says...
Allow other network users to connect through this computers internet connection
john_graydon
Dublin....Ireland
If that dont work run the network wizzard.
beatphreak
40gb Hard Drive
DCC on Laptop
Lancaster UK
Should the dreambox power the light on the LAN socket?
and do i have to assign the dreambox lan socket?
RedDevil_UK
Retired Mod
Rochdale
if you make a connection from you PC to any device, you Lan socket should light up automatically?
im just wondering, you have setup the Dreambox IP address too??
set the IP address up on your PC (ie. 192.168.0.1)
subnet mask 255.255.255.0
when FTPing use port 21 (even though its 80 on the D:cool:
set the IP address on the Dreambox (ie. 192.168.0.2)
Nameserver 192.168.0.1
gateway 192.168.0.1
enable network x
port 80
beatphreak
40gb Hard Drive
DCC on Laptop
Lancaster UK
OK
I will try when i get home from work, but the lan socket is not lighting up when i connect to the DB, but does when i connect direct to network...
I wonder if the DB has a faulty LAN socket??
Again RD
gateway 192.168.0.1
enable network x
port 80
RedDevil_UK
Retired Mod
Rochdale
the other thing to remember is...
when connecting 2 devices direct ie PC to DB, or PC to PC then you should use a crossover(twisted) lead.
when connecting your PC to a network using a hub for example, you should use a straight (non twisted) lead
if your using the wrong lead, the Lan socket will not light up
beatphreak
40gb Hard Drive
DCC on Laptop
Lancaster UK
Cheers for the info...
I changed the cable and run the newtork wizzard and got a connection through flash FXP.
I now need to now how to fire up the soft cams.
Does the Dm7000s have the Dragon and the Matrix CAM in?
I have flashed the Hydra 1.0.8 should this have the latest K*eys in or do i need to put ma*y or someting else in ?
john_graydon
Dublin....Ireland
Yes download the newcamd 5.26 in the cam section, then download marys in the k*ys section. Reboot dreambox and everything should be fine. Make sure you download the latest control panel before you do anything.
RedDevil_UK
Retired Mod
Rochdale
nice to hear the networks working :)
did you enable the internet sharing on your PC?
if so, you will be able to download the new cams and keys with the remote for your dreambox :)
if not, you will have to manually download them on your PC then FTP them over to the dreambox.
even with a new image, its best to download cams and keys...
the 2 most popular at the moment are
newcamD (up to version 5.26)
scam (up to version 2.3)
i dont know about that, im sure someone else will know though
john_graydon
Dublin....Ireland
No it does`nt have the Matrix or Dragon installed. Only downloadable softcams installed. Newcamd 5.26 better than the dragon at the moment.
beatphreak
40gb Hard Drive
DCC on Laptop
Lancaster UK
thanks for this info...
I think i should be able to sort this, but i just have a couple more questions...
What and where is the control panel?
And how do i know if the k*ys are working (what will be unencrypted that usually isn't?
john_graydon
Dublin....Ireland
Use green button,go into hydra set up,select download latest control panel. exit and exit again. then go back into it, the soft cams and k*ys should be the latest at the moment. it will tell you at the bottom date of panel at the moment is 05/01/04 but should 05. its ok though just the hydra team is overworked at the moment. Try S*Y Prima fila ch on 13e these should clear. encrypted ch come up with a yellow box at the top right. ie I S V N (NDS) nds not opened YET..
beatphreak
40gb Hard Drive
DCC on Laptop
Lancaster UK
Tried that , but getting ERROR!
File/Var/etc/Cpanel.xml not found
RedDevil_UK
Retired Mod
Rochdale
have you managed to download anything using the dreambox??
if not, then your dreambox is not getting onto the www
beatphreak
40gb Hard Drive
DCC on Laptop
Lancaster UK
I can see the files through FTP, but i can't get the web on the pc at the same time...
is that what is required?
