beatphreak
- dreambox 7000s - Flubber
40gb Hard Drive
80cm Clear Dish + V-Box 2
Linksys Wireless Bridge
DCC on Laptop
- Lancaster UK
I,m in through FTP and online now
td03-5 said:Hi beatphreak,
I assume the Hydra Zeus image you are using is in dreambox internal flash memory?
The error message you are getting occurs if you fail to do a flash erase (hold in up/down buttons while box boots until 'flash erase' appears on Dreambox display) after loading the Zeus image. You will then need to load in basic and sat settings and do at least a partial sat scan. If you have settings from a 108 image saved with DreamBoxEdit or FlashWizard you can then put these on.
You should then be able to download the latest control panel and then softcams and keys.
73 & good luck.
beatphreak said:Thanks
but when i erased the flash i get no signal through the DB when i tried to scan...
Do i need to re flash?
Mmmmm!
Which box is it?
What sort of dish setup have you got?
How did you install the image?
