Gemini 2.20 and Unknown error 2 on Wireless Lan Setup
E
ebmaster
Likes
Have setup setup wireless connection with my netgear router.
Setup everything and was working ok yesterday.
I have reflashed due to another problem and put gemini 2.20 back on.
When i try and download anything from the net i get a "unknown error 2" back. I have checked and everything looks like its been setup ok.
When i connect from PC using FTP, telnet, webbrowser everything is ok.
Problem is only via the dm500 outwards...any ideas ??
thanx
T
talking_bear
Likes
DM7000
Belgium
#2
hey ebmaster,
i got the same situation on 7000. did u solve it?
E
ebmaster
Likes
only way to solve it is to install the erase image and then run erase from the loader and then install gemini again :-)
I have moved away from gemini now as i had tuning problems with my monoblock LNB. I have installed the neutrino image which feature a built in web site browser ! How cool is that on the tiny dm500 box :-)
Anyway try doing as I suggested if you still plan to use gemini. I hear v2.50 is out now for 7000 series. Might as well try it and see how you go m8.
Good luck....
T
talking_bear
Likes
DM7000
Belgium
#4
tx a lot ebmaster,
i just got the erase image and i'll do it asap.
cheers
T
talking_bear
Likes
DM7000
Belgium
#6
it worked man. good call. tx a lot. i got a gemini 2.4 working now. i must say though that the keys of gemini seem to be late: the hydra keys date 29/11/2005 whereas the gemini ones date 13/11. i had to update keys manually from the web... hope i won't have to roll back to hydra....
cheers
E
ebmaster
Likes
nice one. glad u got it working ok. gemini is normally quite good. i think gemini 2.50 is out now...not sure as i am not too keen on it :-)
