femto
Ey up, Sither!
- Echostar AD3000-IP,
Manhattan Plaza ST100,
Gibertini 1m Dish,
Inverto Silver Tech 0.2,
Polar Mount,
12 Inch Actuator.
- Bradford, W Yorks
Hi, It's been quite some time since I used my Gibbi on its polar mount, as, in another post I made, I'd had a little problem whereby the dish was being removed and due to the weight and length of the pole it was on, hit the ground rather briskly and was made unservicable.
I'm about to go to my local satellite shop to pick up a new dish and polar mount (yes, the mount got bent too
) and I can't remember some details about the mount.
Specifically:
What sort of azimuth range can I realistically expect when using this polar mount with a 12 inch Superjack?
What is the reason for the mount being supplied with two arms? By that, I mean the arm that fits on the top of the mount, where the eye of the jack is bolted through.
I'm going to use the settings on the old mount and dish bracket to set the new one up. I think if I do that, I'll only have to twist the whole sha-bang around the ground post a touch to trim it all up, if I'm right?
Ta very much.
Specifically:
Ta very much.
