Guidelines for positioning a satellite dish
abacas
Triax 70 cm eliptical dish,stab HH 90 motor,Octo LNB,scaffold pole mast ,receiver fortec star innovation.Also mounted on the same mast below the motor dish static sky disk for 3 other receivers.
Ipswich Suffolk
I have recently moved and I wondered if there are any guide lines for siting dishes e.g. trees,buildings,etc.
Many thanks
Try dish pointer on the Site Links button above.
The best way to answer this (initially) is to suggest you have a play with Dishpointer.
There's a link to it at the top of the page or you can Google it.
It neatly pulls together your location and your requirements and gives you most of the answers.
Edit: What hexah said !!!!!!!!!!!!!!!
The tortoise gets there first, for once.
:-rofl2
To jump the gun, if there are trees etc in the way, let Messines ridge be your inspiration. O-Ha
I cannot think that the tragic death of 42,000 people is worthy compensation for line of sight issues :-duel
:o very true :o
Back to the old standby of the chainsaw or errant JCB...
:-sball
