HackSat Keys Downloader for e1 and dm800
tonytr
In old versions had a key deletion problem when web page not working. It's fixed...
Now If web page not working camd selection screen will not appear.
ıf this screen not appear you can understand wep page problem happened.
With this fix your keys will not be deleted.
Also Because of the domain name change new links for key download are added
Hint from Future Releases: Menu and Channel Lock Reset will be add.
HackSat Key Downloader v9 English
hxxp://www.skystar.org/redirect.php?dlid=2712
HackSat Key Indirici v9 Türkçe Sürüm
hxxp://www.skystar.org/redirect.php?dlid=2713
HackSat Keys Downloader v9 for dm800 script version
download and unzip and send files to in /usr/script and change chmod (attributes) 755.
press blue panel for update keys and selecet script and select HackSat_Key_Downloader and waiting to finished
hxxp://www.skystar.org/redirect.php?dlid=2716
regards
tonytr
new v9a version links
fixed cccam constant.cw file
turkish _http://www.skystar.org/redirect.php?dlid=2765
english _http://www.skystar.org/redirect.php?dlid=2766
BIGMAN58
TURKSAT 42 E,
HOTBIRD 13 E,
EUTELSAT 7 E,
SIRIUS 5 E.
Dr£æmßox 500 S,Yu-ma-tu Mx 1000 CI
CCcam & Gbox & Newcamd Server Online 7/24
Dr£æmßox
hello Mr.tonytr i want to send you om message but how to?
please contact me :):confused
mhku
TM Nano ~ sg2100
Midlands
Remember to replace hxxp with http
Have altered it.:)
georgee
commander 5000 ir
cyprus
how can i install it on my dreambox receiver?
also i have commander 5000 ir is it compatible?
mikeisyou
Website Developer and Feed Hunter
Fransat 4K with Basque ETB channels, Octagon SX88+ and Static 1.2m Raven Dish (22w to 33e)
South coast of England
what encryption is this hacksat for
totalacedude
Edit. 5620 several 500,'s (clones) vu duo blackhole pc server 95cms motorised dish blah blahh
crewe
hi, how do i run this ???
new to en2 have ftp'd changed to 755 but dont know where to look to run this!
can any 1 point me in right direction?
ps is there any way like en1 to ftp to a location and manual install because i cant seem to find this option on my 800....
cheers ian
mhku
TM Nano ~ sg2100
Midlands
Not sure if it works with E2 but FTP the file (it's probably a .gz or other unix format file) into /tmp
Then do a manual install from the blue panel:
addons > manual install
The actual menu options/ wording may be different in your image.
