Have a small problem
dig deep
Prince of Birthdays
Dream7020 and AZ Elite and a few DM800
Sweden
My new mobo (soltek sl 865Pro 775) won´t boot
LOaded it with 2*256 dual channel memory, agp videocard and an Intel 775 prescott 3.4.gh cpu
Tries to boot but stops after a while Debug led showing 20 or d9 or 33
Got the boot window once but not completed
Any ideas are more than welcomed:)
Take one of the memory banks out and see what happens, then try the other one on its own.
If it's dual channel memory then I think you need 2 banks of memory at all times.
Are the two sticks of memory matched? If not, this may be the problem. Also, are they the correct speed?
Wasn't that only with SDRAM Paul, thought that all DDRAM could be used as a single stick.
Thank´s guys for Your answers :D
Yes it will run on a singel chip, and Yes I tested that and No same story
Now I will remove it from the case and see if there is a short somewhere, got this tip from a friend at the Den
Then I asked Soltek´s support if they could help, I will have to wait until tomorrow for that one, they work while we sleep:p
Think it is the mobo:(
Started when I used only one mem chip (tested both)
but still won´t install the xp (tried pro and home)
Got the blue screen (tried a fresh new hd, still no joy)
Update !
After many problems I managed to use both memory sticks but not as they should be placed
As this is dual channel system they should be seated in 1,3 OR 2,4 but that won´t work (will not boot) After some tests I have them in 1 and 2 and bios finds 512MB so Ok for now with that
Still won´t install XP (tried both pro and home, fresh install and repair)
Got the blue screen
Tested with my old HD (win xp pro) Black screen
Tried safe mode Starts but stops (all the time) at the very same place
Loading mup.sys and then nothing more
Today I downloded a newer bios, will flash that tonight and test again
Computers are fun, are they not ?:-DOH! 'O'-red :D
LOL, sounds like you're going through the mill on this one Dig, hope you get it sorted. :)
Are you tying to load onto a SATA drive? If so you may need to hit f6 when it is loading drivers to add the SATA driver for the MB. Failing to do this can give blue screen and 'inaccessible boot device'
Anyone know what mup.sys is doing ?
Is that something to do with Kermit and Miss Piggy? :-lmao
in your BIOS, is there an option for Bios Virus protection??? if so, turn it off..
other than that, the general concensus is to flash upgrade the BIOS :(
Update....
Ummm after looking into this i found what maybe the problem.
im assuming the windows version is complete with SP2.
if so, then your problem isnt mup.sys as you think but
c:\windows\system32\drivers\update.sys
rename update.sys to update.sp2
you should beable to boot up/install
once you have booted up and your able to connect online, go here
_http://support.microsoft.com/kb/885626
and get the fix :)
chech after that you now have an updated update.sys file
you DO need this file for windows to run correctly
And if that doesn't work, there is a long thread on mup.sys here. :)
Thank´s again guys
Muppet show is OK but the update could be more useful
Tomorrow is testing time, have upgraded bios ready(in a dos floppy)
But I will try the rename first
Report will come:D
Thank You Rolf for that link (What have I done to You to deserv this:-DOH! ):)
Read the whole thread
21 pages
525 threads
and some 500 ideas how to solve this problem None from Microsoft:o
So I got a pocketful of tips to try tonight No time for no tellie:eek:
Hope U never see this problem:D
LOL, thought that you were an avid reader Dig. :-lmao
Now I am close to waste this mobo'O'-red
I tried everything and still no go
Tested with 1 memory stick, 3 kinds of videocard, 2 hd´s and only one hd, a new fresh HD, flashed the bios, disabled almost everything:) and then tried both the winxp pro and home edition NOTHING works
After a while (like halfway) I got the blue screen, windows was stopped just to save the computer...... First time it suggested a new videocard:-rofl2 and later disabling some memory thingy :-DOH! This mobo must be knackered
Tomorrow will be shopping time for a new board, not a Soltek this time:eek:
Still must be a 775 board and no pc-express Did find a combo board so I think I will give it a try
Boy, this took more than a week:cool: Next time I buy a Dell({}) ready to go
No Dig, get yourself a Toecutter special like I've got. :D
Hmm
this mobo is a toecutter mobo:eek:
