dmw1982
- Apple TV, Sky HD and PS3 run through HDMI splitters to 2 LCD tv's in different rooms.
- UK
I have a Sky HD, PS3 and Apple TV connected to 2 TV's via 2 HDMI cables to each. The PS3 and Sky HD are run through an HDMi auto switch and then splitter to the 2 TV's. The Apple TV stands alone and just runs through a splitter to the 2 TV's.
When everything is connected, the PS3 and Sky HD will not autoswitch correctly - the TV just falshes up different colours. If I switch the Apple TV totally off, then it works fine, and switches to the source that is one.
I can't understand this as the Apple TV is through a separate splitter and goes into separate HDMI ports on the TV's. One thing I have found strange (which is the reason I put the Apple TV on its own to start with) is that when it is in standby the TV does not show a blue screen, as with other sources...just a black one.
Help please.
Help please.
