HDTV with built-in HD Freeview tuner - Is it true ?
good2talk
Nothing at the moment until I find a receiver.
yookay
Expert’s advice will be much appreciated.
I found following info from a website and like to know more to reconfirm that I can get BBC HD channels without buying a HD Receiver:
LG 37" LCD HDTV Model No. 37LC2D
37" LCD HDTV: Get a picture with excellent brightness and outstanding detail from a television set that is stylishly thin at only 5.1" deep.
Built-in HD tuner: With the 37LC2D, it isn't necessary to buy a separate high-definition receiver. The HD (ATSC) tuner is integrated, so you can receive HD programming right out of the box. The HD picture resolution is 1366 x 768 (720p, effective).
Picture refinements: LG's exclusive XD Engine™ upconverts lower resolution signals to near-HD quality and reduces signal noise, while the TV's 1600:1 contrast ratio ensures that images are bright and vivid not dull looking. Plus, the TV's wide 178° viewing angle means that the picture looks great wherever you sit in the room.
Enhanced audio: Enjoying booming surround sound thanks to the 30-watt, two-speaker system and the SRS TruSurround audio enhancement feature.
Widescreen: The widescreen (16:9) aspect mode screen displays movies in their true cinematic format without picture cropping or resizing.
Full array of A/V cable connections: Features HDMI, component video, composite video, S-video, RGB (PC), digital audio out and RF connections.
:-bash
Source:
http://www.circuitcity.com/ccd/prod...BV_EngineID=ccecaddidkdljgmcfngcfkmdffhdfli.0
They do LG tv in the UK & Ireland Dixons & Currys, Maybe a visit there might have one with the right tuner. Think they are a very good tv, lots of extras built into them.
