Complete novice here - from nothing to Gemini (and now broken) in one week thanks to this board! Well - the 'broken' part is down to me - but thanks for the rest!!
Now, my problem. I have a motorised system which is a little 'confused'. The system was installed by a local sat guy who seemed to know what he was doing, so I think I have broken something between flashes...
I wonder if when I perform a flash or 'reset to factory' how the dish position is then calculated. As I now understand, the dish will not automatically move to its initial position (1degW) after power down or power off. So maybe when I flash or reset to factory I should be a bit more attentive to where the dish is currently pointing...
So after multiple 'reset to factory' attempts I now find that Sirius channels are listed in whichever satellite I first scan (when not using gotoXX). I think this means that this is the current position?? Does this mean that I can reset to factory and choose sirius as the first to scanand then can automatically find all others?
have been playing about with gotoXX and recalculate in the motor setup but it is not helping - in fact I reloaded my previous backup via dreamboxedit and selecting my old channels results in a 'no signal found' type message. (I suppose the settings are now corrupted)
I currently have gemini 2.5 installed but will try to use the latest enigma and gotoXX to see if that helps.
1. After a flash or a reset, what is the best way to locate a satellite, given that I currently assume the dish is correctly aligned but I have no idea where it is pointing.
2. The manual seems to recommend gotoXX for motorised setup - this was not setup by the sat-guy (He set 'Use motor input power - 40A' and unchecked gotoXX, then proceded to scan for some signals. If I flash the latest enigma image and select this function, does it matter where the dish is currently pointing?
3. As far as I understand, there is no identifier from the satellite which could be used to sync the dreambox and dish. (Unless this is what gotoXX is all about). Is this true?
My aspiration is to be able to get the DB to understand where the dish is currently pointing and then for it to be able to work out where everything else should be! (All without having to touch the dish!) If anyone can explain the motor config setup pages in slow-mo, I would highly appreciate it.
thanks again
j
thanks again
j
