dynamo82
- Dreambox DM500 and LIDL Silvercrest SL35
1M Dish
Dual LNB
Rotator Rotor Sat HH90
Belkin Router
- Sothern europe
Hello there,
I recently noticed that the sound from some of my channels was on the low side, in fact I had to raise the tv and sat box to full volume to enjoy a movie.
I have a an eaglebox DM500 with Nabilsat software installed CCCam 2.0.11
So I decided to try some meddling. I went on one channel and pressed menu, then setup, system settings, a/v settings
There I found a screen and two of the options which were unchecked were Disable WSS on 4:3 and AC3 default output.
Knowing AC3 is related to audio I decided to check that option. Suddenley this channel had no sound! All other channels had sound. I unchecked it back so to revert to previous settings but the channel is still without sound. I experimented with 3 more channels and the same happened. Now I have 4 channels which I love watching without sound. I tried restarting the box but to no avail. I also disconnected from electricity but nothing.
Help!
Dynamo
Help!
Dynamo
