Help - DM800HD_BlackHole
mikedelta25
hispasat
Portugal
I can not remember how to insert the channels manually. Can anyone help me?
Thank you
mikedelta25
You can use the manual scan option, in Menu, Setup, Service Searching, load a channel list, or use Dreambox tools like Dreamboxedit, or Dreamset.
It is wise to backup your channel list, and Bouquets, using one of the Dreambox tools, when you've completed setting them up.
Yes I use Dreamboxedit in flash, but
On the pen (USB) I can not update the 2 images I have there, maybe problem with Barry Alen so I wanted to update manually as I did before but I do not remember how
Are you trying to use multiboot?
You first stated that you wanted to update your channels, now I'm not sure what you're trying to do.
I can tell you that Blackhole is an image for VU+ receivers, not Dreambox receivers, as it's based on the official VU+ image.
There was a version, of Blackhole, for Dreamboxes, but it's nothing like the genuine Blackhole image.
Dreamboxedit is a program, that runs on your PC, and connects to your Dreambox via the network.
Can you please provide more detailed information, regarding whay you're trying to do, and the problems you're facing.
Good Morning
I use multiboot, I have in flash the Blackhole image, I have in penDrive the images Gemini + Blackhole,
What I can not do is update the channels in the penDrive images without being manually.
As I had the box turned off 18 months, I can not remember how I did it.
(The DM800HDPVR works great with blackhole.)
I know how to operate with Dreamboxedit, DCC, DreamUP OK?
Do you mean you want to load a ready made channel list, like vhannibals?
You should be able to download them onto your PC, or via the menu options, of your receiver.
Sorted out
Friend Mickha
1st the image I have is NabiloBlackHole, sorry for the mistake.
2º as to the frequency of the operators that were interested
LyngSat was only manually put the Frequencies, the SR and the FEC
Thank you for helping
Mikedelta25
