Help!!!!!!!!!!!!!for Digitv
egy78
digitv-intelsat 1002
belfast
I have a digitv box from romania whit 2 slots card , and a 110 triax dish.I,m in belfast,and i know a 80-90 cm dish is enough for a good signal from intelsat 1002 or thor5.but the signal is just 10% .and if i take out the cable from lnb the signal is 10% again.so???i really don't now what to do...if is enyone hwo have any information ,pls pls pls....thanQ
satelliteman
East Midlands, UK & Lanzarote, Canary Islands
Welcome,
More info of your set up would be of some help. There are many things that could cause this ie, dish alignment, box settings etc...
In the meantime, some useful websites to note:
_http://www.lyngsat-maps.com/maps/intel1002_spot3.html
_http://www.dishpointer.com/
Paul :)
egy78
belfast
i stil don't get any signal...i don't now what to do more....i really need help for this setups for digitv romania and intelsat 1002
satelliteman
What's your set up consist of, motor? fixed? receiver?
Do you receive any channels?
egy78
belfast
i have a fix dish wall mounted.i don't receive any channels.the receiver is a hyunday for 2 tvs,but is not any number or another specifications
satelliteman
I'm not familiar with that receiver. Maybe others here are.
Did the system use to work or is it a new system?
Check connections on dish and receiver first.
sg_
45w-52e 80cm VU+ Duo2 (DVB-S/DVB-T)
Northern Ireland
DigiTV is fine here in MidUlster on 80cm.
Do you've another reciever to check if you are getting a signal?. Maybe the tuner in your DigiTV box is broke?.
