Help I've lost Ch4 and Ch5 - again
woodlouse
Skystar2,
Fortecstar Passion HD,
moteck 2100, Lidl 80cm dish
Hi, I have Fortec passion with Diablo cam(with latest software) and freesat s*y card. I used to get Ch4 etc. fine. Now it wont work. The card works in a s*ybox so doesn't need updating.
I suspect the caids file may have changed when I updated the diablo software?
If this is the case, can someone please post a copy of their working caids file.
I tried editing mine in Fausto but couldn't seem to load it into fausto.
many thanks
Have you tried atering the CAID file in teh configuration menu? I seem to remember another member has indicated that you might need to select the UK CAID file.
Which Stealth file was it working with, and which Stealth file have you now loaded?
