Help locating a couple of transistors please
T_G
The Consumate Dreamer
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
Hi tech guys
The heating fan control unit of my Citroen Berlingo broke down, the culprit is a transistor called FW26025A1 (I called it a ***** piece of ***** **** when it was not looking).
The guy from a car forum I found the information from could not locate this transistor, so they took a replacement part MJ11015.
I wonder if any of you tech wizards could please help me find the original or replacement part. Most likely I would want 2 (I think they are used as a darlington couple and need to be equal anyway).
Cheers, TG
Farnell have the MJ11015 -
_http://cpc.farnell.com/1/1/24188-darlington-transistor-3-mj11015.html
Power rating exceeds the original transistor's spec, so it will do fine.
Can't help with a source but there's a helpful guide here _http://www.frenchcarforum.co.uk/forum/viewtopic.php?t=22348
There's a problem with the photos on this post at the moment which I will be fixed soon.
T_G
Thanks.
I got a guide on how to do it on a German site, so that's not a problem.
Only need to get the transistors and some small bolts instead of the rivets they used. Fortunately I got all the bolts, washers an nuts available from work, and I got all the soldering equipment plus a large table mounted magnifying glass with lights. I am sure I will be able to sort this out.
Keeping in mind that a new board will cost 130 or more, it makes it a very worthwile job :)
T_G
Hehe see the google ad on top of this thread
