Help me for cable RS233C
R
reza63
hi.
i want to tell me how make cable RS233C.because i have all the receiver software and can't download to receivers.
guiri
guiri
Manchester, UK
I think you mean RS232.
The site here http://www.arcelect.com/rs232.htm has lots of info - search it for "Cable pinning". You'll need to decide if you need a straight thru or null-modem cable to connect to your receiver. It's useful to have both types of cable really.
M
Mohammed el Hassan
M. reza63
if you need some cabel to make it you can go to the sit that down in the page.
there is maney cable's you can find .
I hope dat can helpe you...........................................
http://www.null-modem.com/NullModem.htm
S
sajidch
Null Modem cable works fine with most of the receivers.Get 2 Female DB9 connectors, a piece of cable and connect pins in the following order
5-5
2-3
3-2
thatz all.....
Z
zaphex
Yes thats correct for humax you need null modem cable:
pins: 5 ---5
2---3
3---2
Thats it. But why you dont buy one m8 you have it any Computer store!
Are you new in patching?? what kind of humax you wanna patch ?
Zap.
