help me
You can help by filling in your profile correctly.
Where is dfgdfg? Not heard of a dfg receiver.
Hello
True I want to do the programming of the card-type Deltacard irdeto access Can it?
If you are hoping to modify an existing subscription card then almost certainly its not possible - modern smart cards are specifically designed to be protected against tampering :D
Hello
Funcard been transferred to the Virgin irdeto 4.1
Can shipment card codes Gama
Jrak we understand English might not be your first language, but your post makes no sense whatsoever Im afraid.
Also you have already been asked once to fill your profile in correctly. We cant help you if we dont know where you are and what receivers you are trying to use.
Showtime is only available on Gamma cards. Havent got the faintest idea what the current status of ART is, though to be honest the subs are so cheap in the Middle East you should be looking at subscribing :D
