Help Mr107 !!!!
neo4051
I've just bought two fun cards 6 and i have a mastera 3 programmer i've downloaded the mr107.upd and used mr funcard splitter to split the .upd file to two parts i've programmed the two funcards with the files coming from using chipcat and when i start the upgrade it says "invalid card please extract it"
WHAT SHOULD I DO PLLLLEAAAAAAAASE ????
Didn't know MR 107 was out yet....although I did read somewhere 106 & 107 were not valid and are fake!.....If I were you I would load 1.055.upd m8 from www.matrixcam.com. that's guaranteed to work unless you are doing something else wrong!
Dead right WR, there has never been a 1.07, it is just a version of 1.055. When programming the fun cards, are you also adding the loader file?
neo4051 said:
I'll try the 1055 one thanks
No problem....glad I could help you m8....WR
neo4051
donot think chipsat can program funcard6 the eprom is too big
therfore your funcards are not programmed correctly
hence the invalid card messages
you may have to look for other software
or use more smaller funcards but more of them
i had to go for 3 x fun5 that the max my programmer could handle
failing that its a new programmer
