Help! My SAB EXPLORER receiver is dead!
boblalux
SAB EXPLORER "black box", Laptop Windows 7, PC XP.
France
Since last night, my SAB EXPLORER is dead !
After turning on the ‘black box’ and TV, I correctly get the SAB logo on the TV screen for about 2 seconds, but then the TV screen goes blank. The EXPLORER is still lit up and on, but I cannot get the menu, either with the remote control, or with the buttons, and I can only turn off the unit by switching the mechanical on/off button on the rear of the unit.
Is something in the box dead (fuse gone?)? The explorer’s screen is still lit up – with the red digits 1, sometimes 7, sometimes 12178 etc, but the unit is frozen.
boblalux
No idea where you get the firmware from for this box or how you re-install it, but it sounds like the firmware could be corrupt. If you can re-install the firmware to it, that may recover it.
Nano
The SAB receivers from a few years ago had the same internals as the Voyager (Satcatcher) boxes
Nano,
Do you mean the software that should have come with the unit? Can't remember ever having any disc. Just plugged in and went to the Menu, but that is the problem - I can't even get to the menu, or at least, it doesn't show on the TV screen.
Channel Hopper: how does that help me?
Thanks, both of you.
You can probably download from either site, and using the correct editing suite and cable, reflash the receiver.
Use the following guide to find your machine and an appropriate live site that deals with the firmware/software
www.satclones.com/history_of_sat/Receiver/wonik.htm
You can find on sabsatellite.nl (original) the firmwares and dvbstand.com (alternative firmwares)
Included the loaders.
