help needed for Astra 23.5 (3A) satellite
feenat
sky
oxford
can anyone advise me on the following
I have a fixed 105 cm dish.
Just having trouble to get signal from Astra 23,5 3A. I am receiving signal from 1G on same satelit /Astra 23,5/
I am using SKYLINK decoding card and there is few transponders like 1G,3A,1M,1E.../
I have signal from 1G just have trouble to find 3A
any help offered would be appreciated
thx in advance
satelliteman
A 120cm needed for reliable reception of Astra3A. Are any of your required channels not also transmitting on 1G?
feenat
sky
oxford
am looking to get STV 1, 2 and 3 etc but i cant seem to get them it says no signal
dish reading currently 88% strength and 92% quality but none of the
3a channels when you go to the channels it says 58% strength and 12% quality
it is like it isnt reading any channels above 12000 mhz
any idea how much a 120cm dish is in UK
satelliteman
Ok so Tp 17, 12.565h. I'm sure your be getting other services on 1G in the 12Ghz range.
It'll be down to dish size. Check site sponsors page for a pricing.
That transponder is ultra critical on skew, as there is a vertical transponder on the same frequency.
Burnham Beech
You should easily get STV 1/2/3 in Oxford with an 110cm dish. Not significantly far from you and getting them at present with an old 80cm dish setup.
Check tips above about alignment and skew.
