Boff
- Humax Foxsat PVR HD, Humax HD, Panasonic DTB30, mini dish and quad lnb
- ipswich
We recently started getting the message 'No satellite signal is being received' on one of our receivers.
My set up is -
1. Humax Foxsat HD PVR with two feeds (bought Dec 08) approx 5m cable run
2. Humax HD receiver (bought Feb 09) approx 15m cable run
3. Panasonic DTB30 receiver (much older prob 5+ yrs) approx 5m cable run then 15m as it feeds via the RF out (then via a powered booster) upstairs to our bedroom; the others are just connected to a TV.
'Sky' type mini-dish approx 5 years old, quad LNB, good quality cabling and F connectors - was professionally installed by local business not Sky.
The original set up was all Sky receivers but we went to Freesat, and a few weeks after the second Humax was installed we noticed that the Humax Foxsat HD PVR was only getting one signal - it would allow you watch one channel but not record another. So I changed a cable over reset everything and the problem appeared to move to the Panasonic which now gave the 'no signal' message. I assumed the cable was the problem but when I tested each individually they all worked fine.
I then checked some forums which suggested the quad LNB was at fault - got a new one, but didn't change a thing.
I then read that some older receivers like the Panasonic lose the power/blown capacitors to draw down a signal, and somehow get the signal from another connected device which explained the moving problem so I got another satellite receiver - another Panasonic DTB30. But still no joy - whatever happens only 3 out of 4 receivers get a signal but the cables are fine and individually all get very good signal quality/strength.
I had wondered if the Humax devices demanded more signal (as they are HD) and somehow my satellite dish/LNB set up doesn't provide enough 'output' to feed 4 demanding devices but I don't know if that's how satellite receivers work.
I'm baffled! And I'm out of ideas... What can I do to resolve this as everything individually seems fine.
Thanks for reading and any suggestions welcome
Martin
My set up is -
Martin
