Help on echostar dsb-770 fta
J
jonesdjat
Likes
I'm using echostar dsb-770 fta receiver,2.4m solid dish.th. pc dell optiplex 450mgh/128mb/60gb hdd/cd-rw +17 monitor.
ghana-west africa
#1
Hi everyone. i am new here.is there any way i can watch scramble channels on echostar dsb-770 fta or besat ddr-700i please help thanks.
Topper
Topper
Amo Amas Amant Admin
Likes
3,346
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
#2
Welcome to the forum jonesdjat
There may well be if your stb has an embedded cam or cam slots. A Dragon cam may well be your answer if the slot is available. I am not sure about the availability of flash patches for those stb's so I suggest you go to the links section and choose a key or patch site and start searching. If anyone here has either of the same stb and knows the answer to your question I am sure they will post here.
K
kalehrl
Likes
Dreambox 500+;
Echostar 770 (Strong 6155);
90cm Triax dish;
Strong DM2100 diseqc motor.
Serbia
#3
It is possible to patch your fta echostar 770. Every echostar receiver with EchoLite siftware can be patched with appropriate strong receiver software.
For echo770 you need strong 6155 software. On www.rdi-sat.com strong section you can find needed loaders, keys and patches. Also visit www.croteam-sat.org other receivers section and find echostar. You will find there same things as on rdi-sat. Good luck!
J
jonesdjat
Likes
ghana-west africa
#4
Thanks guys for your help and direction. You guys are great.
K
kalehrl
Likes
Dreambox 500+;
90cm Triax dish;
Serbia
#5
Another great site for echo770/strong receivers with daily updated patches for multivision www.frocus.net
I
iraj3
Likes
echostar dsb 770 FTA
echostar dsb 1200 viaacs
THE netherlands
#6
hello
can you give me extra information to open upgrade my dsb 770 fta
to open multivison channalen
I was looking to rdi-sat.com and other but i couln't fount the file and key.
can you tell me how to do that
thanks
J
jonesdjat
Likes
ghana-west africa
#7
Hi ! Kalehrl,
Please i have downloaded the softwares from croteam-sat(a: 22.04 eco770 TPS fix by energyps2.rar. b:Key Editor-echostar.zip. c:eco 770 emu.zip (Gkeys 21.0... & ftapatch-1....) ). Please i need your help to do the upgrade on my receiver. ie. which should i load first and what next.Pls help. Thanks.
K
kalehrl
Likes
Dreambox 500+;
90cm Triax dish;
Serbia
#8
Just go to _http://www.frocus.net/main.php?lng=en&rzd=statii&pag=7 and read detailed instructions. Good luck!
I
iraj3
Likes
THE netherlands
#9
Thanks FOR INOFORMATION
I GET THAT, WHAT I WAS LOOKING FOR.
J
jonesdjat
Likes
ghana-west africa
#10
hi! Kkalehrl,
Thanks for the info. I have loaded the parkeges in to the receiver. ie: the bootloader, the urt software. The menu setup have all changed as you said. But all the pacth software I try to load were all (invalid service keyfile).Can you please specify a particular patch file for me? Also I will need a bootstrap for the receiver just in case.When switch the menu comes alright but I cant watch anything. Pls help. Thanks and happy new year.
J
jonesdjat
Likes
ghana-west africa
#11
hi! All,
I have been able to transform my receiver from dsb-770 to str-6150.As you said, i followed the insrtuctions at Frocus.Everything is working fine but after keying the nagra codes for sabc, it still tell me there are scrambled. Is it the patch i used or what. Also i want to know if a patch software works for all channels. Thanks.
I
iraj3
Likes
THE netherlands
#12
I think you dont' know how to work with patch loader
cotact to me via e-mail
J
jonesdjat
Likes
ghana-west africa
#13
Well, first i dont know but now i know. I'm now able to watch sabc.It is always good to learn the hard way. Like i said from the bigging, i know nothing at all about this stuff. So small small i will grow. Now what i need is the nagravision key at nss7 22*west and provider id. If you can help, i will be happy. You know my email. Thanks to all who helped me from infancy. BUT PLEASE YOU CAN STILL TEACH HOW TO WORK WITH PATCH LOADER.
