SK247
- TECHNOMATE 1500 CI FULL MOTORISED SYSTEM WITH 90cm DISH
- London
Hi
I'm a totally newbie & need some help on what system to buy?
Decided to go with a technomate system but not sure what model i should get, i found someone on ebay selling the systems complete with all thats needed dish, lnb, motor, cable etc...
My main aim is recevie the channels that show premiership football but other stuff would be nice.
the systems are:
TECHNOMATE:
1600 2CI MOTOR, 90cm DISH £215
7755 2VA2CI same system £215
1500 CI same system £210
I first thought was to get the 1500 becos it was best entry level recevier last yr but not sure as the price difference is only £5 whether or not to go one of the others? (& don't really know what the difference between them are?)
Some advice would be great.
the systems are:
TECHNOMATE:
