Help re Digisender
sidney reilly
Sky
I hope some of you guys can give me some advice. I have a sky+ box conect by HDMI to my HD tv and it is great. However I am moving into a new rented property and there is no way to get the cables from the dish into the lounge and into the sky box. The house house has a large covered balcony and this is where the dish will be set up. I was wondering if it would be a solution to have the sky box outside with the dish and then connect a digisender to it, put the receiver inside the house just the other side of the window ( within a foot of the sender unit) and connect the receiver to my TV.
Would this work? If it does how would the HD pic quality be and also would all the sky+ features (live pause, recording 2 channels etc) still work....
Thanks in advance
A mains powered receiver outside. Nah not a good idea - if you can waterproof it enough to keep the moisture out it'll probably overheat!
You say there is no way to get the cables in - by which I assume you mean the Landlord won't permit holes being drilled etc.
So have you considered one of the special bits of cable made specifically to deal with a closed window situation? You mention the dish going on a balcony, so there must be door or french window access.
A quick Google or peek at eg Fleabay will show you what I mean. "Flat Cable Window Satellite" as search string does the job nicely.
It would not be outside, it is a covered and enclosed balcony....
If it's covered and enclosed, how will the dish work?
Assuming that isn't a problem, and that we are just missing the essential details that a couple of piccies would help with, how about the cable I referred to earlier?
Yes there are doors to the balcony.... will check that cable out ... many thanks....
Well the flat cable is quite short, so "proper cable" is run from dish to flat section and from flat section to box, connected with standard F connectors.
Do the searches, if you haven't already, and it becomes obvious.
Cheap, cheerful and effective ................. not sure how long they last though, but they aren't expensive and if it solves the problem, so be it.
...not forgetting the guys on this forum ;)
And as a PS. one of our supporting advertisers sell the flat cable, sateuropa.
