Guesswork
- Technomate TM-5402 M3
Technomate TM-2600
Technomate 97cm dish
Standard Sky
- Essex
Ok, Ive installed my system which comprises of a 97cm dish, Technomate TM-2600 motor and Technomate TM-5402 M3 receiver.
My Latitude is 51.7 and Longitude is 0.5.
Ive put in my Long and Lat in the USALS settings, found what i believe to be 1w Thor. I get channels on Thor, albeit slightly low quality (68%ish). The system also finds the satellites from around 7E to 11W, but beyond that I just get a no signal message.
The questions i have are:
1. How can i be sure that i have started on Thor? Is there a channel list available that i can check against anywhere?
2. Why do i miss the ends of the arc? Is it likely to be an alignment issue with the dish and the motor (they look straight to me!) that causes the issue or will it be likely to be something else.
Thanks for your help.
