help software for Mediastar Magic Fox Plus
stive meister
JDHJVHSJKV
evrywhere
does any one of you know how to use simple uploding.is has only port and start. but i don't know what file must be downloded
yhe receiver is Mediastar Magic Fox Plus
Dear meister,
try http://p321.com/upload/ for the latest firmware.
to upgrade the firmware do the following steps:
1. Get a null modem (cross over) cable (9 pins - both ends female)
(I dont know which country u r now - try the electronic shops they probably will sell u the cable otherwise u will have to make one)
for making a null modem cable use this link http://www.uoguelph.ca/~antoon/circ/nulmodem.htm
2. download the latest firmware from the site mentioned above and unzip the files. (it will contain the firmware and a simple upload executable program)
3.. connect 1 end of the cable to your pc/laptop (when u have unzipped the firmware update) and other end to the comm port in the receiver.
4. boot up your pc (make sure your receiver is switched off and unplug all the sat cables)
5. switch on the receiver
6. run the simple upload executable program
7. select the correct comm port (trial and error)
8. press START - after a few seconds a message will appear "waiting for bobb" - press OK
9. look at the display of the receiver - it will boot then the upload should start 1-100
10. after the upload is successfully complete switch off the receiver
your receiver should now run with the updated firmware.
NOTE - U WILL PROBABLY LOSE ALL YOUR SATELLITE SETTINGS AND WILL HAVE TO REPROGRAM THEM AGAIN.
Best of luck,
