HELP -- tit card + cas interface 2 + addon using magic cam
lmac34
Lads newb here just like to say hi to all of you!
i have been searching around on the internet for ages b4 i came across this fourm.
i have just got the cas interface 2 + addon and i would like to start writing the hex files to a tit card but i dont know where to start.
i have seen from some of your posted messages & some of you use the same equipment so if any 1 of you would like to share their knowledge please do.
any files,links or tutorials would help
thanks for everything
lmac34*o2.ie
Hi lmac34,
have you got all the latest updates for your Cas 2 and add on, at present they are upto Cas 5, available from:
_http://www.duolabs.com/download.htm
For files for your Titanium card please try here:
_http://www.sat-key.org/
Click on the Sat-Key Files link, in the right hand pane, and then on the Titanium link.
Best wishes
Mickha
