Hi
Everytime i start my dreambox i have to do the following procedure.
Tap the blue bottom on the remote, then the blue panel pops up
Switch from common interface to betad(i think) at the top of the screen
Then select start/restart cam
Then it all works just fine.
But for some reason, i cant chose betad at the top anymore. Normally i just press the the right arrow on the remote, and it switches. But i can only chose common interfase now. It is like it is locked or something.
I have tryed my remote on another dreambox, and it works just fine there.
Anyone with a brilliant idea?
Sorry if my english is not the best
Frank
Frank
