Help - Where's Sky??
Z3r0
has a Regular Member
Czech Paradise
Has anybody else been having probs with SkyItalia? It suddenly stopped working this morning - I have the latest keys, as far as I know...
I'm using SS2 with ProgDVB - tried three keys posted this week and still nothing...
There's a film I wanna record tonight as well!!! (Universal 23.30 - 'The Following' - short, but pretty good thriller, if you get bored and your Sky works...)
Hi, My sly Italia appears to be fine and my keys are probably a week old or more. I'm using S2emu 1.072 with ProgDVB.Hope this helps, Lucifer..
try right clicking a desired channel i.e Pri/\/\a Fila 2 and then select channel property, in the new window that appears there should be an "update" button at the bottom, press it then "apply" and "OK". This worked for me once when I lost loads of my channels...
Oh and by the way I always get my keys from ~~Mach1~~ over at Toe's:
H##p://67.43.4.157/showthread.php?t=78649
Hope this lot helps you, Lucifer ;-)
Have to ask - why do people put the hash '#' in place of the 't' in the web address.
Sorry if it's a dumb question!
I believe in the forum rules it says you're not allowed to post live (working) links to keys etc. Hope thats cleared that up, Lucifer...
i lost the sky channels with yankse today...but installed s2emu and they work fine...evn with same key?? ONLY problem is the AUDIO is messed up like sounds like buzzzzzzzzzzzzzzz lol... anyone kno why?
Thanks Lucifer - I learn somethink new every day! Mostly here!
Thanks Lucifer - good link man, I'll use this in future, but...
hmmm, so I've got the latest keys, updated S2emu, updated my channels, and it's STILL not right. I can get the occasional Sky channel, but it soon freezes up and lots of them don't work at all. Weird!! It was all working perfectly 2 days ago...
How can I be expected to lead a normal life without Sky???
All OK here.
Can only suggest that you uninstall and re-install everything, and give your PC a good health check while you're at it...
BGonaSTICK said:
All OK here.
Aaaaaarrrrgghhh! I reinstalled ProgDVD, Fenrir, S2emu and Yankse, cleaned up my disk, defragged (PCs other wise running fine) and NOTHING!! Still no Sky!!!
Another strange thing is that all my channels are number 0, though this doesn't stop me picking up most FTA stuff
Just gonna tear what's left of my hair out...
