help with adding hotbird
jojo1212
hotbird nilesat pc
jerusalem
i have a question
i got a 1.2m dish , pointed at nilesat satellite 7W
today i tried to get hotbird at 13E and i succeded
im in jerusalem now and my LAT is 31.78 , LON 35.24 according to my gps
is it possible to get these 2 satellites off one dish
and no MOTOR please, cant use one
thanks all
Possibly, although you would need an offset lnb installing, or maybe a second dish.
my dish is like this one
-http://www.techtir.ie/sites/default/files/1000017_3-off_dish.jpg
do i need new dish for hotbird , or could be possible with this one that i have ??
hi again
I ended up setting a new dish 80cm, since it was so cheap
everything installed , dish aligned
now receiving hotbird with great quality, about 75%
but im only gettin 490 channles, is this what hotbird gives ??
or there is something wrong ?
thanks
jojo1212 said:
hi again
thanks
Dish size most probably too small for location [42dBW].
According to dishpointer, Hotbird 6 & 9 are outside footprint or unknown; not sure how accurate that is.
Not very - Hotbird 6 can be received in India (with biggish dishes) and Hotties 8 & 9 are identical.
jojo1212 said:
hi again
thanks
That would be about right for Hotbird 6.
Yes thought that would be the case re; dish pointer.
i tried to align the 1.2m dish at hotbird 13e , still getting the same 490 channels, so i dont think its a problem of the dish size
if thats right for hotbird 6 , then what about hotbird 8 and 9 ??
the three of them are at 13e , thats what i know !!
how do many people say they get more than 900 channels when pointed at 13e ??
Im talkin FTA
In which case - LNb type, LNb receiver settings?
Three satellites - three different transmission coverage areas. In Israel Hottie 6 is by far the strongest. If you want the others then you may have to invest in a bigger dish.
the LBN is a universal one, not branded , its what they sell here in all the shops
UNIVERSAL is the sticker on it
setting in receiver is , SAT: hotbird ,,
LNB power : on
FREQUENCY : 9750/10600
22khz : Auto (its grayed, cant do nothin with it)
DISECQ : 1.0 @ 2 (my hotbird connected to the lnb2 on the switch)
Analoguesat, as i said i tried the bigger one 1.2m . got the same results
actuallt here most of the time they use 60cm or 80cm dishes , in my area im the one with the biggest dish on the roof
So put a bigger dish up - 1.8m should give you more channels :D
The other possibility is that the dish isnt set up accurately - bigger dishes need more careful setting up.
