help with azbox
T
tomdeg
ECHOSTAR 3000
NORTH WALES
Hi having problems finding the ccam file
Tried opening root dir in dcc nothing in the file
Although in the azbox setup I made the emu priority up with the red button
The yellow to start
If thers any one living in the north Wales area ll28 and could give me some Help
time would be rewarded
gandalfthegrey
gandalfthegrey
Dreambox 800HD (clone)
Gibertini 85cm dish
4 way Diseqc switch........
linksys access point connected to Dreambox..
dublin,ireland
Hi tomdeg..
have you tried to install cccam with AZbox cam wizard?..it does everything for you...I presume you have openxcas installed...
failing that here is a link to a how to _http://www.satdudez.org/forum/showthread.php?t=112527
find and download AZbox cam wizard, (google it)I should be around later if your stuck and hopefully help you out..
cheers,
gandalf
gandalfthegrey
gandalfthegrey
Gibertini 85cm dish
dublin,ireland
Hi again tom...in DCC your cccam file should be located in the EMU folder, have you looked there??
G
T
tomdeg
ECHOSTAR 3000
NORTH WALES
thanks for the reply
looked in emu folder==and 3 sub folders came up
1, home
2, lost + found
3, open xcas
and plugin config
no ccam
T
tomdeg
ECHOSTAR 3000
NORTH WALES
Thanks for the info on azbox cam wizard now on pc
tried connecting with these results
ip connection this is ok
but user name and pass not working
testing with root and azbox
ftp port21
telnet port 23
do i need to change settings on azbox
dig deep
dig deep
Prince of Birthdays
Dream7020 and AZ Elite and a few DM800
Sweden
Yes, in the plugins menu.
Click all the way till You see all cams installed. Should be at least mgcamd and ccc. Then You must remove the # from ccc and put one before all other cams. You can only have one cam active - then You restart ccc by pressing yellow button.
T
tomdeg
ECHOSTAR 3000
NORTH WALES
Thanks again tried that removed # from ccc and
put # before the other cam I made the ccc priority up with the red button
Then yellow to start
Retried azbox wizard with same result IP ok name but password no connection
dig deep
dig deep
Prince of Birthdays
Sweden
So then we know where the problem is.
Password.
The PW shall not be the very same as log in to the box !
The box is root and azbox by default but the pass in ccc should be something else.
Make sure that You change them in both files, server and client then restart both and Bingo :)
dig deep
dig deep
Prince of Birthdays
Sweden
ftp port21
telnet port 23
If I read this again I think You are having problem with the login to the Box ???
What FW ? Try with root and nothing more !
T
tomdeg
ECHOSTAR 3000
NORTH WALES
Tried it with root and no password still a problem with login
I’m not sure where to change server and client
Sorry to be a pest
dig deep
dig deep
Prince of Birthdays
Sweden
How does the PW problem shows ?
Is it whe You try to log into the box or is it when You try to use the CCC ?
The ccc PW are in c and f lines. If the box is new and You haven´t change the pass it should be root and azbox (case sensitive)
gandalfthegrey
gandalfthegrey
Gibertini 85cm dish
dublin,ireland
Hi tom...just a quick question..in the abox wizard, are you actually typing in "azbox"? it's just that it's not automatically set at azbox even though it looks like it is..just a thought..
cheers
gandalf
T
tomdeg
ECHOSTAR 3000
NORTH WALES
typing in " root and azbox ALLSO WITH.. SAME RESULTS .
when I use dcc and clik on emu the the folder contains ccamcass then left and right on ccamconfig this opens a blank page?
J
jsimo01
Dreambox DM800 HD - Sky HD Subscription, Technotrend S2-3200 PCI card.
East Anglia
Same problem, in AZbox CAM Wizard the IP checks out fine but it will not log in with the default password (I have not changed it, ftp with filezilla / telnet with putty is fine)
dig deep
dig deep
Prince of Birthdays
Sweden
Could be a corrupted pass file.
Log in using telnet and change the password just to be sure.:)
T
tomdeg
ECHOSTAR 3000
NORTH WALES
Hi thanks to all
Just to let you know I now have ccam working
And just trying it out in a new azbox premium.
The problems I’m finding its not has stable has the DB800
I’m thinking it could be an software problem firmware 0.9.2880,ccam 211
what s your thoughts
tom
dig deep
dig deep
Prince of Birthdays
Sweden
Yes, it is a FW problem and we all wait for the next one.
There are a few newer FW out but they are not official (however the latest is working rather OK)
Those FW are to be downloaded and put on an USB pen for install.
T
tomdeg
ECHOSTAR 3000
NORTH WALES
Still trying to get this az box running without freezing I am using the latest firmware 0.93501 and CCcam
i find it only runs with one line but needs rebooting two or three times each evening
dig deep
dig deep
Prince of Birthdays
Sweden
There is a full ccc, download it from the plugin (also download the config file)
T
tomdeg
ECHOSTAR 3000
NORTH WALES
can you explain the use of the config file
thanks
