help with electron/arion/liberty/ferguson/openbox
D
donpely
Digital 4100ci, fortec 5100 ultra, Technomate 1500CI, geotrack motor, 110cm dish+0.2 lnb
leeds, uk
hello there,
i need your help in patching my receiver. i have a electron fta. i got some files from h**p//laki.dvhk.pl/fredka.htm and struggling on what to do. since those files belong to arion model which i take is the same as the electron. what do i need to do. which file should i run as there are numerous files there from the model from the AF3018SE. other receiver you just plug in the modem cable and the rest so easy but i have not quiet grasp how it work with electron/arion/liberty and so on. can you help out please
