prof 573v3
- sky +HD
Comag sl100hd
- London - United kingdom
Hi every one i'm a neewbie here so sorry if this sounds dumb.
i live in a flat with a comunal dish for astra however i want to pick up turk sat but due to a wall i have a limited veiwing window for 42 east.
using a OAS flat 440 (square) i can easily get turksat but i have some overhang on the balcony which is not allowed.
i want to know has anyone tried the rectangle type ie squish, neo vh200, selfsat hd10 at a 90 degree angle.
i wondered if i did rotate one of these and did a blind scan not using presets.
1) would it work
2) will it think that the vertical is now horizontal and vice versa.
If anyone is willing can someone try it out on any satellites and let me know asap i need to order one as soon as poss.
i understand that after rotating by 90 degrees i would then have to add on the skew.
cheers in advance (fingers crossed)
1) would it work
