Help with Fortec Pasion !!
readbmr
Want advice on buying a hd satelite reciever
DORSET
Hi can anybody tell me what a B Grade is? ie if you look on Maplins Website the fortec Passion is 149.99 but underneath there is a B Grade for 99pds? does this mean its the same model or that you can only buy from their website, ie the B Grade 1...
Hope to hear soon from Brian
Well Brian with most goods but especially electrical it means they are either catalogue returns or units that have had a minor fault but have been repaired and re-tested.
