Hi guys,
I was wondering if anyone could help with the flash file for Horizon HDSM USB meter (not USB PLUS)? I was trying to upgrade the software on it and it seems to have killed it. Basically I have used (Sky Q) software which was suggested here on the forum and all RF/transponder values have gone bad (they fluctuate between 0 ~50, do not detect/lock onto the signal...) I am not sure if the RF/tuner card has gone bad or if it is just matter of re-flashing correct file. This Q software works fine on HDSM USB PLUS but it does not work on HDSM USB.
Not sure if I am loading it wrongly (using SatEdit HDSM 1-23 User) or if the whole different new files need to be used for HDSM USB meter? In the past I used to load same exe file (for both meters) and it was fine but unfortunately don't have them any more as they were on my old HDD which broke.
Any help to recover these two HDSM USB meters would be greatly appreciated.
PS.
I have tried every list suggested on this forum.
PS.
