Help with Hotbird and positioner
80cm dish with Topfield receiver.
I have a old pace MSP 925 dish positioner and trying to fine tune the dish(80cm old precision type), as most channels have no signal. I mange to pick up a couple of transponders under hotbird, but not the italian channels.
I have no problem with Astra, 99% signal strength!
Couple of points:
Is there a way to move the dish in small fractions at a time. Each time I press the east or west button on the remote, the dish moves about a 2cm a time. I need to move in mm! Could this be the case or
Could it be the vertical positioning of the dish that may be out, as i been told that astra and hotbird are not the same vertically! BTW the dish was able to pick up anaulogue Hotbird channels after i changed LNB to uni type (.3).
p.s. the positioner is not connected to a receiver, just using to position dish to hotbird and then will be decommissioned! Cannot manually move dish by hand, cos the motor.
The Hotbird satellites are higher in the Sky than the Astra 1's
