Help with Manhattan Starlight 6900
N
nilefish
DB 500 S,Strong 4622, Viasat Denmark card and receiver, Moteck 2100 Motor, Triax1.1 dish, infinty programmer, cas interface2.
South London
This receiver developed a fault (Went in into
'constant boot mode' I tried to put the power on and off but nothing change any ideas plaese
Many Thyanks
john_graydon
john_graydon
Dublin....Ireland
Many Thyanks
I was reading a while back that you can load boot software into the receiver if the boot fails & am nealy sure it was for a Manhattan. I cant remember where i read it but just google for it with the words "bootloader" Maybe that will bring something up. If I come across it again I will copy it for you.
N
nilefish
South London
Thanks alot for replying I contacted Manhattan technichal Dep. and I got this message from them ( This could be a hardware fault with the receiver. We suspect it is the Flash EPROM that is
failing and will need replacing and re flashing.) so I think u r right ..please let me know if u get any more information's .
Thanks again
F
FASTFORMAT
P4 3500mhz PC HD DIGITAL VARIOUS SAT BOXES WITH 1M ROTATING DISH FEEDING HD PROJECTOR
U.K.
Thanks again
CONNECT NULL SERIAL MODEM CABLE BETWEEN SAT BOX & PC. DOWNLOAD BOOTLOADER & IMG FILE FROM MANHATTAN-RECEIVERS.COM & LOAD THE TWO ONTO YOUR RECEIVER. THIS WILL WORK (DID ONE LAST NIGHT) SAME PROBLEM AS YOURS
misterminibus
misterminibus
Lancashire
Kodi
Lancashire
@fastformat
I have a stb with this fault too, will this definitly work?
R
robloman
1M DISH TECHNOMATE 5000CI
DEVON UK
i have a manhattan 7000 and have done this procedure many times yes it works .....but if it gets turned off chances are it wont boot back on again!! and the trouble is each time you flash it you have to start from scratch with the install etc
misterminibus
misterminibus
Lancashire
Kodi
Lancashire
thanx guys its sorted
