Help with mrv ...Please
nilefish
DB 500 S,Strong 4622, Viasat Denmark card and receiver, Moteck 2100 Motor, Triax1.1 dish, infinty programmer, cas interface2.
South London
Hi
I would like to see tps on hotbird , I got some files like mrv220tps.zip but I don't know how to use it with mrv cam , can someone help me please
nilefish said:
Hi
The painless way would be to use a CAS2 programmer together with the CAS Studio 5 application from _www.duolabs.com.
mrv220tps file has the .bin file which is simply uploaded to your Cam, following the instructions in the program.
Thanks I will go for the Cas 2
Im unsure why you would need a Cas2 device as the MRV would normally be recognised if it was put directly into the laptop PCMCIA slot
Most of the sites putting down the latest 2.20 file also have the right drivers for the operating system, and the UCAS loader alters anything 2.0 or above to the latest.
Or am I missing something here ?
The problem is the laptop may not recognise the cam.My cybermax/medion laptop does not.I do not have a problem using the laptop to update an x cam.I used an xcam serial loader and mutznutz or cammy software to update the mrv cam.
