Help with multivision/TPS
nilefish
DB 500 S,Strong 4622, Viasat Denmark card and receiver, Moteck 2100 Motor, Triax1.1 dish, infinty programmer, cas interface2.
South London
Hi every body..
it seems to me I'm the only one who is not enjoying multivision this weekend . I done alot of reading and tried diffrent files with funcard 6 & 4 but nothing happened..I have mrv which was converted from mr , do I need cas 2 ? please explain in details ..many thanks
nilefish said:
Hi every body..
If you get yourself a Cas 2 interface + an add on you will be able to program almost all the cams and cards that do the business. If you download the latest version of a prog called MR Crypt, you can write you own MRV or MRL.bin files as well, a very easy prog to learn. But in the meantime download a prog called
Sep v1.2 and make your own funcard 6 files from an MRV.bin or .upd file.
Thanks Satellite babe I really apreciate your help I think I will go for the cas 2 interface , but do i need to keep the dynamite programmer ?
Thanks again
