Help with my MR cam!
amerwaqar
13e
19.2
west yorkshire
i need some help and advise on programming my Matix rev cam i have MRB 3.00 software.
i most recently lost all TPS channels:( but i find that others are working fine e.g BBC Prime, Eurosport 1+2
i firstly would ask to why this has happened with only the TPS channels and to why that other still remain open.:confused
secondly can someone help me to re-programme my cam and explain the process,
thanks.
bigkenny
North Wales
VU+ Duo and Dreambox DM 518-S also a Technomate TM-6800HD using 1 metre dish with motor
North Wales
amerwaqar said:
thanks.
The TPS keys change daily I use a Matrix Reloaded and flash the CAM up with new .upd files (with new keys) I use my laptop (you can get a CAS interface which is better as can do more things with it).
Files are posted on the `net other forums
amerwaqar
13e
19.2
west yorkshire
Cheers, BIG Ken
but is there away that i can do this through remote control with a fun card, its just that i read it some where in one of the forms.
thanks.
frund
triax 1.1 tm 1500ci+ dm patch. Moteck 2100. Intel 4300 based pc . LG7500. 32" lcd
Wales. UK.
If you have an active cas menu on screen then you can imput your new keys with your remote, that is how us tm users do it. Or you can repatch bit of a nuisance if like me your pc is a room away from your box..:D
amerwaqar
13e
19.2
west yorkshire
How would i enter letters via remote, my remote as numbers 1-9???
regards,
a.w
Hexadecimal, in two figures, is entered using decimal notation as three numbers.
lilitheking
For you information, it is not possible to add aes keys with remote control on matrix cams firmware.
You have to program you cam with "cas interface" or other tools.
Few days ago, aes keys were only for Multivisions but now they affect TPS too!
So, mrb300 is out for TPS & Multivisions and there is no way to add aes keys on it!
Regards
amerwaqar
13e
19.2
west yorkshire
if i was to enter the right KEYS, where would i insert them
cas set up, select cam (M Rev / M reb)
options
1.Edit cas key
select viaccess 1
options!
select ID Provider (007C00)
options!
1.0x08 ~ 0x0b, selected
options
0x08???
0x09???
0x0a???
0x0b???
