Hi, could someone help me. I usually set up quattro LNBs by connecting my meter to an output on the multiswitch (using a long cable). My dish is not giving me any signal at the moment. Now it could be that we have recently had a storm and the dish may have moved slightly, or it could be the LNB or multiswitch. I wish to connect the meter directly to the LNB, but as its a quattro do I need to change any settings on my Rover as I don´t need a polarity switching voltage or a tone to switch from high to low band. Will I cause any damage just by connecting the Rover as it is (with the voltage and tone switching)? Will I get correct readings? Thanks.
