Help With Runaway motor
rich0398
Motorized 1.2M Channel Master
18 Inch Super Jack
Protek 9760HD IP
Inverto Black Ultra LNB
Earl Shilton Nr Leicester Uk
Hi all. Just had my install done on a motorized sat. All was working fine for a day then the problem started. When i move from satellite to satellite sometimes the motor will send the dish straight over to the east limit. Iam using a Protek 9760hd ip with a vbox2.
Ive done a reset on the box & checked all the wiring. Iam thinking it could be a fault with the vbox.
Thanks.
Rich
Update on the problem is the vbox2 had a internal fault. replaced it & now all is good.
Rich
Glad you got to the bottom of it.
Hey Rich, how come you are not using your 1.5m dish? What's the performance difference between the 1.2m CM and your 1.5m PF?
