billnot said:
Sherry, as rolfw says, you can fit a quad (or even octo) LNB to your existing Sky dish. That's the way to go rather than have two dishes pointed at the same satellite.
Since you have two dishes, one at 19,2º and one at 28,2º, you could fit a Disecq switch to your SL-65 and have it receive from both satellites. The best of both worlds - something a Sky box won't do!
Hi Billnot,
I'm afraid we're getting a bit to technical for me now!!
Please explain in simple terms as I don't understand quad LNB's and Disecq?????
It would be difficult for me to get to the sky dish as it's higher up on the wall.
If it's ok (ie not illegal) the simplest thing for me would be to leave existing dishes alone and add the small new one I've got(still got to drill holes and lead another cable though, sob!)
Then I could carry on with sky digital freesat as this is working fine. Use my old analogue receiver to pick up Eurosport and CNN or something like that?(or just get rid of it as I never watch Eurosport anyway!)
Since I already have the twin LNB and small dish I would not need to buy another LNB (and I'm not sure I could get to the dish anyway as it's too high up).
Do you think it is ok to have another dish on my wall(making 3 in all?).
I think I can see by looking at the existing dishes that the smaller sky one is already pointing where I'd need to put the new one ie 28.2 deg. The old one is pointing at the 19.2, I can see this now after being advised how to move the old one to get it pointing at 28.2!!
If I could of got to the old dish and it wasn't so rusty I would of moved it but I'm afraid that is beyond me.
I am sure you guys would be able to get to my sky dish and do what you say with a quad LNB but again I think that is beyond me as already stated the dish is too high up for me.
Please could someone explain what you can do with quad, triple, dual LNB??
I understand you can connect more than one receiver but is it like having multiple LNB's? ie can the receivers all be receiving different channels at the same time? (from the same satellite of course
Also what is a Disecq Switch? Sounds like something you can use to connect more than one dish to a single receiver and then choose which one to view (a bit like having 2 TV aerials going to a TV via a switch box and choosing which transmitter to receive?).
Sorry I am going on a bit but I'm trying my best to understand you all and
am very appreciative of all of your help.
sherry x
